New system TIEM!!!
Re: New system TIEM!!!
Postby f1xxx3r » Sat Nov 14, 2015 13:43:35
And I re - re -redecided on the 980ti because a 144hz monitor is cheap enough to get shortly after and the 970 can't put out stable 140+fps in Overwatch (unless you set everything to low).
Basically:
You want pcmasterrace 144fps ? 980ti
You want stable 60fps and pretend it's 1998? Best value 970/390.
LE:I'm spending a shitload of money anyway, might as well bump it 30% and get the full experience
LE2: OMG I'm this upgrade for me is going to be ridiculous:
6 processor generations - q2quad -> 6th gen core
4 gpu generations and upgrade from high range to enthusiast: 2010 6970hd to 2015 980ti
Postby King » Sat Nov 14, 2015 16:16:14
well that'll be rather noticeable rather quickly then xD
Postby f1xxx3r » Thu Dec 03, 2015 08:10:23
Robbed Santa...
Postby B00rz » Thu Dec 03, 2015 20:05:14
Just aswell you went with the 980ti instead of AMD this time, 20% fan speeds psh!
Postby f1xxx3r » Thu Dec 03, 2015 20:26:55
B00rz wrote:Just aswell you went with the 980ti instead of AMD this time, 20% fan speeds psh!
The 980ti from GA is faster than a fury-x at exactly the same price so... yeah :D
The fury-x is water cooled though but the GA 980ti turns off fans completely in idle so I will never know who is quieter.
I went with the fractal define r5 case because I got a crazy deal on it (much cheaper than the corsair 240) and hopefully it will block the coil whine noise if the video card will have any.
Didn't buy an i7 or a maximus and used the extra cash to get a proper psu, water cooling and a hdd :D
Can't wait to finish putting it together after I finish some overdue work :D
I also have my eye set on a 144hz 1080p gsync monitor so I can use the video card properly. But that's in about a month's time :D
Postby B00rz » Fri Dec 04, 2015 00:22:46
DO IT NOW, make it so!
Postby f1xxx3r » Fri Dec 04, 2015 02:13:09
It's assembled, it booted, bios is updated but it's 3am and I've gotten 12 hours sleep in the past 3 nights.
Think I'll install windows tomorrow and start taking it for a spin.
Postby King » Fri Dec 04, 2015 13:29:38
:D
Always fun doing stuff like this, sod doing it at 3am though, good call on the sleep.
Postby f1xxx3r » Fri Dec 04, 2015 14:04:15
Windows is installed, bf4 is downloading :D
Postby f1xxx3r » Fri Dec 04, 2015 16:52:29
Fucking pos engine game always dropped to 40fps or even less on some maps on 1080p high...
What about 130fps everything dialed up to eleven ?
Users browsing this forum: No registered users and 162 guests
