Link to frontpage from forums won't work on my phone.
Edit: forgot to check in another browser. I'll check that later.
var bottomAccordion = new accordion('vertical_container');throw(container+" doesn't exist!");
f1xxx3r wrote:
- Code: Select all
ends up with:
- Code: Select all
If you're using JS to resize the shoutbox or whatever then fix the accordion issue. 1 js error in IE usually breaks all the js on the page.
Users browsing this forum: Majestic-12 [Bot] and 10 guests
